Upgrading to a 90mm or bigger throttle body? We have a short sale!
Are you in the market to upgrade your throttle body to a bigger size? If so, we have a great sale for you! This sale is for LS1 Tech members only and only until Monday! You can choose from either a FAST 92mm or 102mm cable style throttle body or a Accufab/CBM 95mm and 105mm throttle body.
The 92mm and 95mm will receive a free intake manifold adapter. The adapter is for a LS1/6 and truck intake manifold to a 4 bolt LS2 style 90mm+ throttle body.
The 102mm and 105mm will receive a free reducer. It is made for a 90-95mm intake manifold opening going to a 102-105mm throttle body. 4 bolt throttle body design only!
This is a free $80 value! Offers only good by using a special code on our web store or a phone call to Sean (909) 291-7550 EXT 2004 If you see another throttle body on our store that does not have a discount code, give us a call and we will make you a special deal!
Here are your special discount codes! Enter them in after you put the item in the shopping cart. Click on the code to take you to the product.
FAST 92mm Throttle body - LS1tech92
Accufab 95mm Throttle body polished - LS1tech95p
Accufab 95mm Throttle body black - LS1tech95b
FAST 102mm Throttle body - LS1tech102
Accufab 105mm Throttle body polished - LS1tech105p
Accufab 105mm Throttle body black - LS1tech105b
