Painless performance 12 circuit race/prostreet wiring harness
Category: Accessories
Price: $600
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): FL
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
If you are looking for a switch panel and harness to keep your racecar streetable, then these Painless performance 21-circuit harness and switch panel combos are for you. These harnesses include an optional connector if you want to use a GM column mounted ignition switch. The included switch panels are a roll bar/dash mount 8 switch rocker panel. These panels are prewired and are a direct plug and play into this harness. Also Included is a painless mounting plate, grommets, terminal assortment kit, and the necessary connectors for your turn signal switch, headlights, and alternator. Each harness is custom printed with the circuit identification as well as using GM color codes for easy installation.
Each harness includes circuits for:
* Accessory #1
* Accessory #2
* Brake lights
* Charging
* Dome light
* Electric fuel pump #1
* Electric fuel pump #2
* Electric water pump
* Emergency flashers
* Fan relay activation power
* Fused power source
* Headlights
* Horn
* Ignition coil
* Park lights
* Radio and gauges
* Starting
* Tail lights
* Third brake light
* Turn signals
* Wipers
