2000 Camaro Z-28 Secondary fuel pump relay behind headlight switch?
Hey guys, My Z-28/SS decided to crap out on me and all of the sudden wont fire up at all.
Verified 0 lbs fuel pressure @ rail.
Verified underhood relay is in proper working condition.
I don't even drive this car, its unregistered, but it fired up a couple , three weeks ago.
Took driver's side kick panel off to check the other relay, and its not there. I have 2 LT1 cars, which is why I looked for the other relay in that location.
I called my local GM dealer - and they mentioned that in their diagram, its showing a second relay in the dash somewhere on the driver's side, possibly behind the headlight switch.
Is this right?
Anything else I should check before I get the cut-out wheel out and put a racetronix kit in it?
Is this right?
Its probably your fuel pump, but its always good to eliminate the small things first. I have an 01 Z28 I just changed the fuel pump on and I didnt even consider the relays. In short, USUALLY its not an electrical problem....pumps fail eventually and its probably your time.
