FAST 90/90 Issue(s). Help!
I have a 2002 Pontiac WS6 LS1. Just had a 90/90 FAST combo installed but having issue with the throttle cable reaching the throttle body. I tried to drill the TB cable plate holes larger to move the cable farther up but it till seem to be a little short. Also, when I leave the TB cable off of the plate it seems that the TB is not closing all the way. Lastly, if there is no easy fix for this issue, can I fit a stock LS1 TB to my FAST 90 intake? Thanks for your help.
Your stocker is 3 bolt, a fast has a 4 bolt flange. So no. Please post a pic of what you have, and put the drill down, nothing good can come from it. And to adjust the blade stop, look for a small allen screw near the half moon cam.
