6.0/4L80 in Jeep TJ, which mods would you make to motor ?
Hey all, thinking about installing a 6L/4L80 with a ford 8.8 rear in a 2000ish Jeep TJ. They weigh around 3000lbs and the conversions are common...
http://www.novak-adapt.com/knowledge/tj_swap.htm
I'd like to know what year 6.0 I should get and the cheapest/easiest bang-for-the-buck mods would be...I'm thinking a good converter and ?
Keep in mind this will be a daily driver and they already make 360+ hp (in a short wheelbase 3000lb Jeep) so no wild cams or power adders lol.
thanx for any input, help,suggestions.
Not sure where my original reply went but I'll try tj remember the questions I read.
My jeep is an 06 LJ Rubicon, kept the 241OR transfer case, motor is an 04 LQ9 rebuilt with forged mahle internals, z06 cam, PRS stage 2.5 6.0 heads.
I went with the Fast LSXRT intake, LS2 Throttle body, Fast 46lb injectors, walbro 255 in tank pump, custom 3" air I ntake, Sanderson headers and a custom 3" single stainless exhaust with a hi flow cat and magnaflow muffler.
Trans has an HD2 kit, I'd recommend the jake over Transgo just because this one is aggressive and I'll he swapping it out soon.
I used a Speartech harness and went with a 12 volt unlimited instrument cluster with autometer sport comp 2 programmable gauges.
Novak: engine mounts, lokar shifter, novak tcase linkage, novak radiator/shroud and spal fan.
If you love down south in the heat I personally would just do a custom davis racing radiator and source a lincoln mark viii fan.
The only issue I had with the swap was heat on the freeway when it's 90+ outside,
Imc currently waiting on novak to send me a larger replacement radiator which I'll be swapping at the same time I do the lincoln fan install and ditch their shroud/spal fan.
