Injector Connectors?
So i have a 2005 5.3 truck engine and am using the original harness. my question is i know that the connectors are delphi, but iam trying to get a set of 80lb/hr injectors for it but i am not having any luck on finding the correct ones,as to all i can find are EV1 and EV6 connectors..... someone please help....part # or a link or anything, iam ready to start building boost and a tune.
Still confused.
Your current injectors use that connector ? And you are buying new injectors ?
So you want the new injectors to have the same connector ?
Would be a lot easier just to change the connector or make a short adaptor.
Yours seems to fall under Multec2,
http://www.bmotorsports.com/shop/pro...roducts_id/604
http://www.racetronix.biz/items.asp?...atus=0&Tp=&Bc=
yes the current injectors (stock) use these connectors, and iam looking at a set of 80lb/hr but all i could find was ev1 and ev6 style of injectors that use the ev1 and ev6 style connector. if i could find injectors that use what i currently have would be the best but if i have to change the connector then thats what ill end up having to do.
