NX Maximizer 2
NX Maximizer 2
Category: Accessories
Price: $300
Location (State): OK
Item Condition: Used
LS Engine?: Fits LS Engine
Features:
* Dual Stage independent output channels (independent profiles for each channel)
* Time-based ramped delivery of nitrous and fuel (unique programmable delay and ramp times for up to 8 gears)
* RPM-based delivery of nitrous and fuel (unique programmable curve for up to 8 gears)
* Throttle-based modifier of nitrous and fuel (reduce nitrous delivery by up to 35% based on throttle position)
* LEAN threshold automatic “cut-off ” when using FJO Wideband system
* Programmable RPM trigger point and cutoff
* Programmable MAP cutoff (when using nitrous as an 'anti-lag' system)
* Nitrous pressure sensor input
* Built-in MAP sensor reads from vacuum to 48 psi of boost
* Gear detection for manual and automatic transmissions
* Inputs for arming switch, bottle heater enable switch, 2 trigger switches, throttle position, tach signal, nitrous pressure, and Air/Fuel Ratio (narrow or wideband)
* 2 configurable outputs for either: integrated bottle heater control, integrated bottle opener control, automatic N2O purge function, or status LED
* 2 ignition retard outputs
* Digital communication port for PC or digital gauges
* Easy to use graphic set-up menus and datalogging using Windows™-based PC
* High current 2-channel solenoid driver
* Available for on-line purchase.
