393ci Forged Short block, complete Frankenstein ported 317 heads, Fast 90, ETC..
Category: Engine - Complete Motors
Price: $1
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): IL
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
I REPEAT, UNTIL THE SHORT BLOCK IS SOLD NOTHING ELSE IS BEING SOLD.
Parts can be spoken for and if the short block sells I will sell stuff to the first people that wanted it. Anyways....
Short block is a Burger's built, ls1 block, stroked to a ~393. It has 4.125 stroke, 6.125 rod, and 3.903 piston. The crank is scat, the rods are scat, and the pistons are lunati dome pistons +5cc if i do remember correctly. It has a couple passes on it. Cam in it has ZERO miles and is 254/262 .623/.596 112+4. And it does come with a pro products under drive pulley and hummer "hot rod" pan, and front and rear covers, Ls6 valley cover, ls7 lifters, ebay head studs- $2500obo
The heads are 317 heads that were bought ported at TSP, then sent to frankenstein and opened up even more. They have 2.04 intake valves and 1.65 exhaust valves. BTR .660 Dual springs installed, stock rockers with trunnion upgrade, and I'll send the 7.350 pushrods with them. The heads are shaved a decent amount, as the pushrod length suggests. With the dome pistons, it was around 12:1 compression. Will include powder coated valve covers. Heads were never ran-$1500obo
Fast 90 with billet rails and crossover, drilled for direct port but they're plugged atm- used - $780
Deka 60# high impedance injectors- new- $280
Godspeed 102mm throttle body with tps, new-$150
Meziere Electric Race water pump, new- $400
Uncut motor plates-$80
Billet alternator mount-$120
Heat sink truck coils with custom bracket- $150
Like I said, nothing goes without the short block being sold.
Im selling the short block for what the rotating assembly costs, the heads for what they cost from TSP, and everything else cheaper that what it was. I was doing this for a project I lost interest in.
PM me so I have them in case short block sells
Thanks,
Dylan
If you are looking to buy the long block I can make you a deal. That would be a seperate deal. It can run either na or up to a 200 shot. With the long stroke no more than 200 can be ran though.
