99 ws6 built transam
Year: 1999
Make: Pontiac
Model: Trans Am
Price: $17000
Mileage: 61
Private or Dealer Listing: Private Listing
Location (State): TX
Color: White
Transmission: Manual
Drivetrain: Rear Wheel Drive
Engine:
421 CID Lq9 6.0 iron block ,9:12:1 compression "went low for high boost" machined by Houston Balancing and Machining , 244/258 on a 114 custom cam, 80lb injectors ,Cnc ported stage 3 243 heads, Ferrea valves, ATI super dampner with a/c pulley ,PAC springs, tool steel retainers, mahle forged pistons, scat rods and crank, ARP 2000 bolts, cloyes timing set, melling HV oil pump, edelbrock super victor intake "ported" , elbow and FAST 92mm throttle body, full suspension , performance k member , polyurethane motor mounts , act twin disc clutch rated for 1200 , chromoly hardened push rods , kooks long tube headers , Texas speed and performance true dual dump exhaust ! All FORGED internals no corners cut !
Only thing you have left to reach stupid power is to replace :
•stock rear end for digs but u can roll race
•supercharger or turbo
better contact 504-275-8713 for a million detailed pics of the build
Do yourself a favor.
You are probably going to have trouble finding someone to buy it for that amount when it isn't proven at all. You should be driving it every day to get the 500 miles you want on it and then getting it dynoed and tuned correctly. I'm sure all the money is there and that its worth it but trusting that there aren't gremlins in there is a tough one.
Look great though.
GL
Look great though.
GL
