ring and pinion swap
I know this has been discussed a lot, but I need to make a quick decision on what to purchase. Car is an 02 Trans Am conv. Basically stock LQ4, pcm retuned and has traction control. Gets 20 mpg around town an 25+ on the highway. Plenty of acceleration for a daily driver with the original 2.73 gears. Posi is going and it is developing a clunking sound so I plan to rebuild a rear axle assembly over the winter and swap it in. This way I can keep the car mobile while I gather parts, rebuild,etc. I have a decent deal on a used rear end assembly ( complete) but it has 3.23 gears. Question is how much of a hit will I take on MPG and can I retune the PCM with my Tech II or do I have to send the PCM to a tuner?
sounds like your city is pretty rural 20mpg in REAL city traffic isnt happening even on a full moon lol. anyway the 25mpg figure seems realistiic for hwy. With that said gears will help your "city" mileage out a bit at the expense of the hwy... although with a modest gear swap to 3.23's i doubt it will be noticeable really. the 3.23's are a pretty good gear so you'll be happy with those as they'll reall ywake the car up but i'm not sure if the tech II can do the change.... if anything you may just be able to swap in a stock 3.23 gear tune if your car is stock
