Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
c5 corvette tc/ah disable, removal?
Old 09-21-2014, 09:21 PM
Violence.z06's Avatar
Default c5 corvette tc/ah disable, removal?
Looking to make my 03 z06 more for drag racing. Skinnies in the front slicks in the rear. Ive read about tire sizing messing with the active handling. How can this be disables? I plan on lg drag spindles and 15" wheels out back. Rear tire i want to run is 29" tall.
Old 10-21-2014, 01:22 PM
C5_Pete's Avatar
My car has all the AH/TC stuff removed. It was done prior to me buying the car. I believe it can all be adjusted and/or deleted in the tune.
I have 15" strange brakes up front with 15" wheels and the LG drag spindles in the back with the MT 275 radial pro tire.
Old 11-03-2014, 06:20 PM
blackcoupe04's Avatar
Theres a button to disable them on the console. Owners manual says press for 5 seconds but for mine its more like ten. I turn traction control off and leave active handling on... just in case lol
Old 11-14-2014, 11:36 AM
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
There is also a plug in controller that will allow you to set which mode the car goes into. The LapTrax controller allows this. With it you can set it to default to AH, or off completely.
You might consider setting it to Competitive Driving mode which allows wheelspin, but if you "loose it" AH will kick in and help save the car for you. So, say you get out of the groove and the car decides to try and come around, AH, can kick in and help save you.
Quick Reply: c5 corvette tc/ah disable, removal?
