What do you think it will put out?
I just fnished a head, cam, oil pump, timing chain swap. I still need to take it to be tuned. What do you think it will make on the dyno?
here are the specs:
Absolute speed stage 2 LS1 heads, an older version, they flow 307@.600 int and 228@.600 exh, 298@.550 int, 225@.550 exh
Comp cam specs 224/224 .558 lift 115.5 lobe sep
APE ported oil pump
SLP dual roller timing chain
SLP longtube headers with cats and an ATR pitbull 3 in exh
LS6 intake
MTI lid
ATI superdamper 10% underdrive
the car is a M6 with a McCleod clutch into a 10-bolt with 3.42 gears
here are the specs:
APE ported oil pump
LS6 intake
MTI lid
