Induction Solutions Real Street Plate Kit
Category: Accessories
Price: $900
Location (State): IN
Item Condition: Brand New
LS Engine?: Fits LS Engine
$900
If you are looking for the best two bar (1 nitrous/1 fuel) plate in the business, this is IT!!
The Plate
The plate is ½” thick with stainless steel spray bars. One of the things that make this plate unique as well is that there are two nitrous discharge points for every one fuel. This equals better flow, atomization as well as distribution and horsepower.
The Solenoids
The fuel solenoid is the standard .156 orifice based fuel with filtered inlet. The nitrous solenoid is modified to a .120 orifice for improved flow, has a PTFE plunger as well as a low AMP coil (8-10 AMPS) it also has a filtered inlet fitting.
I-S Flowing
Each I-S Real Street system is flowed and comes with custom jet mapping from 100-400+ HP. This kit includes all S.S jets for each power level.
Complete Kit Includes
* 10LB bottle, mounting brackets, bottle nut (-6), -6 supply line
* I-S blueprinted plate, lines, solenoids, solenoid bracket, inline filtered fittings
* Electrical hardware including WOT switch, arming switch, power relay and connectors
Extras included in Complete Kit
A couple of extras we have included in this kit to make it a true complete kit are a -6 purge kit, racer safety as well as a 1 ½” liquid filled nitrous pressure gauge on the bottle.
