High end aftermarket speakers
Category: Audio/Video/Electronics
Price: $1234
Location (State): PA
Item Condition: Used
LS Engine?: Fits LS Engine
Infinity Kappa series 60.5CS with tweeters and crossovers, $75
•Ceramic Metal Matrix Diaphragm Plus One woofer cone
•1" C.M.M.D. dome tweeter can be flush-, surface-, or angle-mounted
•hi-roll rubber surround
•2-way crossovers (high-pass/low-pass at 3500 Hz, 18 dB/octave)
•frequency response 45-21,000 Hz
•power range 2-90 watts RMS
•peak power handling 270 watts
•sensitivity 90 dB
•top-mount depth 2-3/16
Alpine SPS-17C2, $40
•2-way car speakers for 6-1/2" and 6-3/4" locations (pair)
•aluminum-coated woofer cone with air-injected rubber surround
•1" pivoting silk dome tweeter
•square voice coil design and Nomex spider
•power range: 2-50 watts RMS (250 watts peak power)
•frequency response: 35-30,000 Hz
•sensitivity: 92 dB
•mounting tabs for use in 6-3/4" openings
•top-mount depth: 2-1/4"
Infinity reference series 652I, $40
•Plus One polypropylene woofer cone is 30% larger than other speakers of this size, ensuring strong bass response
•high-roll rubber surround allows greater woofer movement
•3/4" silk semi-dome tweeter may be rotated up to 355° for improved imaging
•sensitivity 92 dB
• frequency response 54-20,000 Hz
• recommended power range 2-60 watts RMS
• peak power handling 180 watts
•top-mount depth
