Oil recommends for COLD weather
Going to start getting cold here.... May see -32 f or so a few times in my area. I remember the LS1 not really liking it last year. Had some chatter all the way to work (5 miles) I am currently running Castrol 5-20 syn... What should I use during the cold weather..????
Many on here will suggest the GC (German Castrol) 0W-30, BUT, that is one of the thickest 0W-30s on the market, beaten only by Red Line's 5W-30, and a few others in HTHSV (high temp, high shear viscosity).
IF you are unwilling to mix oils (which many are, but usually NOT for good reasons), then you cannot go wrong with the Mobil 1 0W-30 AFE, or IF it stays VERY cold ALL winter, their 0W-20 AFE, or EP.
The Amsoil SSO 0W-30 mentioned above by redtan is also a good oil, and is also thinner than the GC 0W-30, with at least a slightly higher VI as well.
There are NO very high viscosity index 30 weight oils on the market, and the only way currently to get one would be to mix oils as I do (a sky high VI insures a thinner oil at ALL start up temps, within a given HTHSV range).
An example would be; 2-2.5 quarts of Mobil 1 0W-40 (185 VI), mixed with 3.5-4.0 quarts of one of the high VI, car manufacturers' 0W-20 oils (Mazda Genuine high moly Motor Oil 0W-20{221 VI}, Toyota Genuine Motor Oil 0W-20 {216 VI}, or the harder to find, and more costly, Eneos Sustina 0W-20 {229 VI}.
This yields ~ a 3.0 HTHSV, over 205 VI oil which should have NO problems getting quickly up into the heads/valvetrain, even in Arctic Circle type ambient temps.
I personally use 2 quarts of Red Line 0W-40 (190 VI), mixed with 4 quarts of the above mentioned Sustina 0W-20 (229 VI), to give a VERY high VI, ~3.0 HTHSV oil, in the winter, with more of the Red Line for summer.
YES, this IS costly, but I live for oil overkill!
I will try out the 0-30. Only reason I need to change in the winter is that I have some valve train chatter (maybe its piston slap) on short trips to work in the winter once it starts getting really cold out. The other option is drive my truck that gets 8mpg all winter... but the GF lives 30 miles away and driving the truck back & forth gets a little expensive.
Save the manuals!
That's what I recall from my research a long long long time ago. (I had the fortune of moving into a heated garage shortly thereafter.). Now, I'm contemplating running on low oil for a while to see if I can gently wear out the engine - in hopes that I can then get a rebuild (with more power) approved by my residential budget committee...
