S60 Gear Swap
Old 10-09-2014, 12:15 AM
CaptainCrunch42's Avatar
Default S60 Gear Swap
How hard is it to swap gears in my Strange S60? It currently has 4.10s in it but I am debating going to a higher (numerically lower) gear since I am doing a lot of cross country driving. Since I know nothing about working on the drivetrain, what would I be looking at to have a shop do this??
Old 11-04-2014, 06:36 AM
oldmano2z's Avatar
I have the lowest gears @ 3:54's in my s60 and would like to go higher myself and would like to know the same thing. carl at crp should be able to help with your question.
Old 11-04-2014, 10:53 AM
Carl at CRP's Avatar
The S60 does not require the old and dreaded case spreader required for a gear swap on the Dana 60. Nor does it require the shims used to move the carrier right or left.
Here are a couple of links You might find helpful.
Hope this helps.
Carl
Quick Reply: S60 Gear Swap
