Factory pushrods are how strong/weak?
Old 05-24-2004, 08:48 PM
guadofreak's Avatar
Default Factory pushrods are how strong/weak?
I have been spinning mine to 6700 for quite some time now. TR224 and 918's with no problems.
Do i HAVE to change them? I am going to a larger cam and double springs? Is this a no no? I like them as a "fuse" of sorts..info please.
Old 05-24-2004, 08:49 PM
guadofreak's Avatar
also in case it gets overlokoed I CAN use an LS6 oil pump as a direct replacement for my old LS1 oil pump right?
thanx ~Eddie
Old 05-24-2004, 09:02 PM
ulySSes's Avatar
Might as well switch to better/stronger pushrods when doing a cam swap, especially if you rev that high.
Old 05-24-2004, 09:35 PM
SMOKIN01TA's Avatar
thanx ~Eddie
yes
and you deffinatly need to have hardend pushrods or you are risking a big accident with that much seat pressure at those rpms.
Old 05-24-2004, 09:47 PM
guadofreak's Avatar
WOW...I need to proof read more often. Sorry about that abortion called typing above from me.
Well I guess hardened pushrods it is...
thanks and thanks.
Old 05-24-2004, 10:07 PM
benningtonz28's Avatar
thanks and thanks.
????????????????????? say what?????????????????????????????????????????
