68-69 Galaxie 9inch into a 99 Z28 ?
Old 10-19-2014, 07:41 AM
madmike9396's Avatar
Default 68-69 Galaxie 9inch into a 99 Z28 ?
I recently came across this 9inch housing with very minimal $ invested.
I believe me and my brother can cut it down and remove the old mounts and re weld new mounts for it to fit into the z28.
He is a Pipe fitter/ Welder so we will have access to welders torches plasma cutters and what not.
I believe the hard part will be figuring out how to do the Torque Arm .
Ive been looking and I can not find the Width of the rear ends on our fbody cars.
if anyone has a similar thread or build please point me in that direction.
im looking for as much info on this as I can find before we start hacking into it.
my idea right now is to find a stock 10 bolt to look at and measure from.
thanks to anyone with info or good advise
Old 10-19-2014, 10:28 AM
guppymech's Avatar
Not to rain on your parade but you can get a Moser F-body housing w/ta mount and axles/bearings for about a grand. The stock ford carrier in the galaxie rear is probably plain cast iron vs. the stronger nodular units that came in the Hi-Po cars, people post about blowing those up quite frequently. Do your research and Good Luck.
Old 10-19-2014, 05:21 PM
FirstYrLS1Z's Avatar
https://ls1tech.com/forums/gears-axl...ng-length.html
Old 10-20-2014, 03:22 AM
Thanks ! yea im still doing some digging and I have found 1 or 2 threads on these kinds of swaps.
Old 10-20-2014, 03:23 AM
Thanks for that Link !
Old 10-20-2014, 03:25 AM
I just have the Housing not the whole center section. I will be looking into the Nodular pumpkins after I get the mounts in the correct location.
Quick Reply: 68-69 Galaxie 9inch into a 99 Z28 ?
