"Project" 52mm LT1 throttlebody
Category: Engine - Intake/Fuel
Price: $75
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): NC
Item Condition: Used
Engine: LT1/LT4
LS Engine?: Non-LS Part
First the bad news. As shown in one of the two pictures, two of the holes for the bolts that hold the coolant/iac manifold broke into the bores. I believe a very small amount of jb weld or even silicone at the bottom of the bolts would fix this problem with no issues. However I'm not 100% sure it would and I want to state that upfront. I think some very good common sense will fix this. Now for the good news. I will include the following new parts: GM gaskets for iac/coolant manifold and top plate, two new 52mm blades from TPIS (with receipt for proof), mounting screws for blades, and an airfoil with mounting hardware. Used parts include the following: old throttle blades, throttle return spring, TPS sensor, bolts for mounting to intake manifold, throttle cable bracket, throttle shaft, screws for mounting the iac/coolant manifold to bottom of body. The coolant/iac manifold and iac motor do not come with this. Please look at the pictures for a good inventory of what you'll get. Paypal only please. Email me at mtopczewski@yahoo.com for questions. Thanks for looking!!
