Cam is in...but not the springs...why didn't somebody say those were shims...
Ugh. Well the hotcam is in. I bought the pen magnets...and boy am I glad I did. I heard 2 of the lifters slip out of the retainer. I even got the dots on the sprockets lined up on the first try. So I end up with a new problem. Those things I was told are retainers aren't retainers. They are shims.
So I am weighing my options, and I need a little help from you guys. Do I:
1) not use the new shims
2) buy new valve seals and replace the shims
3) buy the newest valve stems seals with the shims built on
I don't want to blow a gazillion dollars to finish this up, but I so want to try to finish it up right. How much do new valve stem seals cost (for all 16)? And do I really need to do all of this (the valve stem seals can't be bad on mine, I only have 34k miles)? If I don't replace the shims, what are the drawbacks? Valve float? Thanks again in advance!
SN95 Director
are you refering to the spring seats? the ls6 springs should fit no problem in the stock seats so you dont really need to replace them. only time you need new spring seats is if your installing a dual spring setup. in which you'll also need to replace the vavle stem seals. and 01 superslow is right, you only need 16 and i got mine from thunder as well.
The spring seats that come with the hot cam are .010 thicker than stock LS1 seats. Using them will change the installed spring height by that amount and will slightly increase the spring pressure. The newer 02+ seals that are one piece with the spring seats are the same thickness as the hot cam seats. If you decide to change them, I would go with the newer seals as the springs will self install the seals at the correct height. The newer seals are only a few dollars more than the older seals.
02 INTAKE V/G SEALS – 12482063 – Dealer List $17.68, Dealer Cost $10.08
02 EXHAUST V/G SEALS – 12482062 – Dealer List $20.11, Dealer Cost $11.46
98-01 INTAKE V/G SEALS – 12533586 – Dealer List $17.12, Dealer Cost $9.76
98-01 EXHAUST V/G SEALS – 12457652 – Dealer List $15.74, Dealer Cost $8.97
