FIC injector data (62psi @43.5)
A friend is working on a swap car I'm trying to help get a base tune on. He has FIC injectors and the flow sheet says they are matched to 62lbs @ 43.5psi.
I used the spreadsheet found online to convert IFR to 58psi rail pressure but cannot find any other data for them.
I know when I changed from stock to GM 42# injectors I changed much more than that based on some data I got from a member here but I cannot find more detailed data on these injectors.
Does anyone have anything?
