Fuel Injector Sale @ Hinson Motorsports
Old 11-10-2014, 11:07 AM
HINSON Motorsports's Avatar
Default Fuel Injector Sale @ Hinson Motorsports
All of our Fuel Injectors are on sale!
Most injectors will max out at 80% duty cycle and this is the accepted industry standard. After you install heads, cam, intake, your sucking in alot more air and your motor needs more fuel! Your injectors will be unpredictable when maxed out and you do not want to be running out of fuel at 6000+ rpm. If you have any questions about which injector size or accessories you may need, feel free to ask them in this thread.
High Impedance
FAST 33lb Injectors LS2
Part# 30332-8
DeatschWerks 35lb Injectors LS1
Part# 18U-01-0035-8
FAST 36lb Injectors LS1
Part# 303608
DeatschWerks 39lb Injectors LS1
Part# 18U-01-0039-8
FAST 39lb Injectors LS3/LS7
Part# 30397-8
Bosch 42lb Injectors LS1
Part# 0280155968
DeatschWerks 42lb Injectors LS1
Part# 18U-01-0042-8
DeatschWerks 42lb Injectors LS2
Part# 13U-00-0042-8
DeatschWerks 42lb Injectors LS3/LS7
Part# 16U-00-0042-8
FAST 46lb Injectors LS2
Part# 30462-8
DeatschWerks 50lb Injectors LS1
Part# 18U-01-0050-8
DeatschWerks 50lb Injectors LS2
Part# 17U-00-0050-8
DeatschWerks 50lb Injectors LS3/LS7
Part# 16U-00-0050-8
FAST 50lb Injectors LS3/LS7
Part# 30507-8
FAST 55lb Injectors LS1
Part# 305508
FAST 57lb Injectors LS2
Part# 30572-8
DeatschWerks 60lb Injectors LS1
Part# 18U-01-0060-8
DeatschWerks 60lb Injectors LS2
Part# 17U-00-0060-8
FAST 60lb Injectors LS1
Part# 306008
Siemens 60lb Injectors LS1 - EV1
Part# 107961
Siemens 60lb Injectors LS1 - EV6
Part# 108191
DeatschWerks 65lb Injectors LS3/LS7
Part# 16U-00-0065-8
FAST 65lb Injectors LS3/LS7
Part# 30657-8
DeatschWerks 72lb Injectors LS2
Part# 17U-00-0072-8
DeatschWerks 78lb Injectors LS1
Part# 18U-01-0078-8
Siemens 80lb Injectors LS1 - EV1
Part# 110324
Siemens 80lb Injectors LS1 - EV6
Part# 109991
FAST 85lb Injectors LS3/LS7
Part# 30857-8
DeatschWerks 88lb Injectors LS1
Part# 18U-01-0088-8
DeatschWerks 90lb LS3/LS7 Injectors
Part# 16U-00-0090-8
DeatschWerks 95lb Injectors LS2
Part# 17U-00-0095-8
Low Impedance
Lucas 120lb Injectors LS1
Bosch 160lb Injectors LS1
Fuel components you may need for your build
Caspers Electronics Injector Adapter EV1 to EV6
Part# 109076
LS2/LS3/LS7 Car using an LS1 Injector
Caspers Electronics Injector Adapter EV6 to EV1
Part# 109077
LS1 Car using an LS2/LS3/LS7 Injector
FAST Injector Harness Adapters - EV1 to EV6 (8 Pack)
FAST Injector Harness Adapters - EV6 to EV1 (8 Pack)
FAST Fuel Injector Spacer Kit
Makes an LS3/LS7 Injector have the same height as an LS2 Injector
Katech Fuel Rail Spacer LS2
LS1 Injector in an LS2 Manifold and Fuel Rail
Old 11-18-2014, 10:51 AM
Thanks for the orders.
Old 11-27-2014, 03:18 PM
WVhuggerSS's Avatar
What injectors are usually run on ls7s? This is going in a fbody with a factory ls7 intake. What style and size would be recommended and with the harnesses to adapt then
Old 11-28-2014, 09:54 AM
It would depend on what rails etc your running as well. PM me your setup and I can get you set up with what you need. Thank you for the interest, we look forward to helping you out.
Old 12-08-2014, 06:49 AM
LS6427's Avatar
Hinson.....
I have 12 year old 42 lb injectors on my LS6 intake. I will be boosting my new 390ci at some point. I will be using a FAST 92mm or 102mm intake when I do boost it.
Which injector do you have on sale that will accommodate 1000 RWHP......and will also work just fine right now on my N/A 390ci until I do boost it......AND will work in both the my LS6 intake and FAST intakes....?
Thanks...
Old 12-10-2014, 01:55 PM
Originally Posted by LS6427
Hinson.....
Thanks...
Unfortunately there is not an injector I can recommend simply because the injector that will work at 1000rwhp would just be too much injector for your current NA setup.
Old 12-10-2014, 05:08 PM
LS6427's Avatar
Ok....what injector do you have on sale that will fit my LS6 intake and a FAST intake.......just for my 390ci.....figure about 480 RWHP.....
Old 12-10-2014, 09:07 PM
drain89's Avatar
I need injectors for a 600 RWHP NA 408 with LS2 rails and EV1 connectors. What are my options and costs?
Old 12-11-2014, 03:51 PM
Ok....what injector do you have on sale that will fit my LS6 intake and a FAST intake.......just for my 390ci.....figure about 480 RWHP......
These will get teh job done nicely
http://www.hinsonsupercars.com/p-155...injectors.aspx
This one
http://www.hinsonsupercars.com/p-644...ctors-ls2.aspx
or this one will work depending on your budget
http://www.hinsonsupercars.com/p-156...injectors.aspx
Old 12-11-2014, 04:29 PM
LS6427's Avatar
Will this work for my 390ci just fine also.......little cheaper...???
Old 12-19-2014, 02:49 PM
For some reason the link you posted isn't working. What was the item?
Old 12-21-2014, 10:26 AM
Anthrlsxfox's Avatar
What injectors do you have on sale for a ls3 intake and rails @ 1200 hp using pump gas/race gas?
Thanks
Old 12-22-2014, 01:49 PM
Thanks
This one should get it done.
http://www.hinsonsupercars.com/p-157...injectors.aspx
Quick Reply: Fuel Injector Sale @ Hinson Motorsports
