BNIB Comp cams trunion upgrade SOLD
Category: Accessories
Price: $120
Location (State): PA
Item Condition: Brand New
LS Engine?: Fits LS Engine
Converts a stock LS series rocker arm into a roller trunion rocker arm
Valve train technology leader introduces new premium trunion upgrade for GM LS1 rocker arms to optimize both performance & durability There’s no denying that the GM LS1 engine platform has proven itself as a performer. The valve train is no different, with an improved design that makes for a perfect combination of power and durability to complement the impressive cathedral port cylinder head design. The rocker arm design features a lightweight, yet stiff rocker body that is strong enough for most applications. However, when it comes to high performance racing applications, high rpm and high valve spring pressures can put the factory rocker arm’s trunion under intolerable stress. Enter COMP Cams® with a new LS1 rocker arm retro-fit trunion kit that replaces the cageless, loose OEM needle bearings and powdered metal trunion with a premium 8620 steel alloy trunion and caged roller bearings for added durability. The new design from COMP Cams® utilizes caged roller bearings that greatly reduce the possibility of the bearing failure experienced with stock LS1 needle bearings, which can send loose needles throughout the engine upon failure. Perfect for drag and circle track racing applications that mandate the use of stock engine components, this performance rocker arm modification is a “must have” upgrade for your LS1 factory rocker arms. As proof of success, for the last two years this rocker arm trunion upgrade has been tested and performance-proven in the NASCAR GM LS spec engine series
Straight from a site
