FS: TR6060 1LE Transmission Complete Swap
Category: Accessories
Price: $3750
Location (State): NE
Item Condition: Brand New
LS Engine?: Fits LS Engine
Monster LT1-SC that has been upgraded to handle 1000whp+ less than 500 miles
TR6060 mm6 1LE with 7,000 miles
1LE Short Throw Shifter
Manual console
Clutch Pedal
GTO Reservoir
Tick Hard Clutch Line
New GM Slave Cylinder with 500 miles on it
Monster Billet Bearing Support (Replaces plastic piece in slave that tends to melt)
GM 2010+ manual transmission mount
Cooler Lines
1LE Stock Drive Shaft
Asking 3750 for everything
Might interested in parting out but please pm me.
I am going to see if i can grab a picture, everything is out and ready to ship. I could have it shipped out in 2-3 days depending on carrier.
I also have a
DSS Carbon Fiber Driveshaft for tr6060 to Gforce 9" Rear end
- Could work something out on this if you have the correct rear end.
Gforce/Dynotech 4" Driveshaft for tr6060 to Gforce 9" Rear end
- This one does vibrate, run out is all in spec so i assume something inside the joint is causing the issue. It does have a lifetime warranty. I would throw this in if you have the correct Rear End.
