If you don't have L1 in your car shifter, read this thread !!!
Hi guys
last year i bought a 1997 Chevy camaro and i don't know why , but it doesn't have L1 in the shifter...
this was not really good , so i tried to fix it
i am going to explain you how to fix it in your car , if you have the same problem
1- open this two bolts inside the console
2- push the black piece down, the white thing goes up . turn it to the left and remove it ( be careful to do not loose them)
3-pull this C-clip off
4- here is some plastic that wouldn't allow you too move the shifter backward. Cut it and remove it
5- give that piece too your friend to eat that ( very important)
Now you can use your L1 !
