Power steering issues
So, a few months ago, I replaced the pump, rack and lines on my 99 z28 and it worked perfectly
well a few days ago, the pump started to whine real bad when I first started it up, and the fluid was foamy and aerated. So after 2 hours of bleeding and several overflows, same problem.
I don't know if it's a bad pump(reman), or air is getting into the system from the o ring between the pump and reservoir(maybe due to the new cold weather) because I do have a small leak somewhere around there
Anybody have any advice?
also it does not have a PS cooler
