Rear end question
Rear end question
I've heard that the stock rear end on f-bodies are notoriously fragile. What is it that actually breaks? Does replacing the ring and pinion set solve the problem or is it more involved than that? Just thinking ahead as I plan a tranny, TC, H/C package upgrade
There is no way around the problem but to buy a new rear. If you have an A4 it will live longer than a M6. I have a couple hundred into my stock 10 bolt and plan on beating it until it
yea, you should definitly plan on getting a new rear with those mods planned. either a gm 12 bolt, or a ford 9", which is actually a lil stronger than the 12-bolt. i'll be gettin a 9" myself within the next month or two. either way, your 10-bolt aint gonna last.
