Can you swap out 98' steel fuel tank 99-02 plastic one?
I have a 1998 Trans Am LS1. Has anyone done this and is it a straight swap out?
If not, what modifications would I expect?
Thanks in advance.
Thanks in advance.
I haven't thought of that but I have compared some of the 1998 to 1999-2002 fuel tanks on eBay and it is hard to completely tell if the components are the same between the two. I did search the forum hoping someone had done this swap and had posted a write up, but apparently not. If I do this project and it entails that I modify anything to work for my 1998 Firebird TA, I'll document and post a write up with pics. In the meantime I hope anybody can shed some light on the project. Thanks
May I ask why would you want plastic? Weight?
I'm glad I have metal since I needed to have my tank fabd for new pumps ... worked out for me
There are two reasons I want to do this.
1. I have a bit of a rust issue and want to have a winter project.
2. Maybe the weight but mostly the 1.3 gallons increase, which negates the weight decrease with a full tank.
If you all can in the mean time, please continue to offer more info to back up the possibility that is an "Easy Swap".
Thanks, Joe
