H/C M6 looking to get 60' in the 1.4s help
My best 60 to date is 1.56
Car setup as of now:
-4.10 gear
-26x10.5 ET bias ply on stock wheel
-Stock front shocks with strano springs
-Koni rear shocks and strano springs
-stock rear sway bar, front removed
-UMI tunnel mount TA
-UMI lcas and panhard
-lca relocations
-mwc SFCs
The plan:
-26x10.5 slick on a 15x10
-Viking or qa1 double adjustable front coil overs with 300 lb springs
-viking or qa1 adjustable rear shocks
-ain't roll bar/drag sway bar?
-rear springs? Stranos ok?
The car is NA M6 now but eventually be 4l80e swapped and possibly nitrous. So I need a setup that Wil be compatible with both transmissions. It's my goal to get a 6.9x NA with the t56 before I swap to the 80e. My best now is 7.22 @ 96mph 1.56 60'. I am also goin to remove some weight with front and rear bumper supports and also possibly a fiberglass hood. Need all the suggestions I can get. Thanks
-4.10 gear
-lca relocations
-mwc SFCs
The plan:
What's the race weight? For my car the biggest improvment is when I installed my MWC front end. Strange singles, k member,lower control arms, manual rack. The car transfered so much better. Went from high 1.5 but mostly 1.6 60 ft times to 1.48. Still on stock rear shocks also.
