PO 530 DTC resistor for AC delete??
Old 01-23-2015, 03:42 PM
dailydriver's Avatar
Default PO 530 DTC resistor for AC delete??
Does anyone have a clue as to whether or not a resistor placed into the connector for the AC pressure sensor harness will eliminate this code and the resultant SES light?
I removed my AC system, and only when I go WOT, I get this code and light, after only one cycle
(I am guessing because the ECM is sending a signal to the compressor to cut off and there is nothing there to recieve/confirm it?).
IF a resistor will work, does anyone know what rating I need to keep this code away until i can get it written out by a tuner?
Thanks in advance,
Dave H.
Old 01-25-2015, 02:31 PM
ANYONE???
Or do I HAVE TO have this written out by a tuner (preferably one with a CMR program, so I can still use my Predator hand held tuner), as the ONLY way to get rid of this code?
Also, does the same hold true for the EGR delete, that a re-tune is the ONLY way to keep the SES light off?
Old 04-20-2015, 01:05 AM
FormulaTA327's Avatar
Any update on the ac delete... I'm in the process of doing that right now
Old 04-20-2015, 04:47 PM
No, I still don't know what resistor (IF any) will keep the P0530 codes away when one goes WOT with the defroster setting on the HVAC dial.
I just had a tuner 'write it out'.
Quick Reply: PO 530 DTC resistor for AC delete??
