Notices
Wanted LS1 Water Pump
Old 01-24-2015, 08:19 AM
TDMKR496's Avatar
Default Wanted LS1 Water Pump
I'm looking for a used LS1 water pump. Really just need the pressed in inlet insert so if it has a bad bearing that's perfect, let me know what you have.
Old 01-24-2015, 11:10 AM
LS1-450's Avatar
We have one. It stopped pumping. Don't know why, just that when it spins it does not move fluid. If this is what you are looking for, LMK.
Am looking for a bad yoke to use as a plug when we pull the drive shaft to tow the car. Any chance you have one?
Old 01-24-2015, 09:30 PM
TDMKR496's Avatar
What kind of trans?
Old 01-25-2015, 08:36 AM
LS1-450's Avatar
What kind of trans?
T56. The yoke from a 4L60E will also fit.
Old 01-25-2015, 04:59 PM
LS1-450's Avatar
Found one. So, no longer nee the yoke. Let me know if you want the water pump.
Quick Reply: Wanted LS1 Water Pump
