Stumped on powering fuse box.
Old 02-01-2015, 07:52 PM
JustAFooL's Avatar
Default Stumped on powering fuse box.
Ok, I'm all done with my turbo build and I've had to relocate my battery to the trunk.. I've got a distribution post mounted on the frame rail and I know that I have to power my starter, alternator and fuse box.
My alternator has been relocated to the passenger side head and I was able to get the factory plug over to it. The distribution post was placed where the cars factory wiring will reach for the starter, I just have to cut and put a new end on it. That should take care of those 2.
Now is where I got lost. The factory wiring to the positive side of the battery had 2 red wires and one black. The red and the black went to the fuse box I believe ( judging by the length of the wires that's the only place I can figure). Why would their be a ground coming off the positive post of the battery?? Also, I know that the fuse box has the stud on the side of it to power it, where does the other connector go? Thanks for the help.
Old 02-01-2015, 08:49 PM
red_00z28's Avatar
On the stock cables the black went to the alternator and the one red went to the fuse panel the other red went to the starter.
Old 02-01-2015, 08:56 PM
JustAFooL's Avatar
Ah!! That's all I needed to know! So the fuse box nor the alternator have a ground?
Old 02-01-2015, 09:19 PM
Spartan7's Avatar
Most alternators ground through the case to the engine (which is then grounded to the chassis), the fuse block will have its own ground to chassis.
Old 02-01-2015, 09:21 PM
JustAFooL's Avatar
Ya, there is 2 or 3 grounds right below it that I have done hooked up.. I'm assuming one was for it.. I'll check it tomorrow.
Quick Reply: Stumped on powering fuse box.
