TH400 help needed please.
Hey guys i have been doing research for a while now, and can NOT find very specific details on what i need for this swap. From what i understand i will need
1.A flex plate, either 6.0 or i dont know...is there a company who makesthem specific for this swap?
2.I could use my M6 mount if i modify it correct?
3. cooler and lines
4. converter, who makes the best and does it have to be lsx specific?
If someone could chime in with a complete parts list or how they did it i would appreciate it! Its going in a 2004 gto btw
3. cooler and lines
a flex plate and trans cross member with torque arm mount, I suggest running a aftermarket cooler and fabing up the lines make sure the cooler has a fan and the a shifter and a driveshaft
Not sure on a goat, but for mine when i did the swap, had to Have a driveshaft, flexplate (bought a TCI flexplate) Transmission Cross member with torque arm mount, Shifter, Also got a Cooler, and a transmission temp gauge.As for converter i bought an FTI converter
As i said not sure what all is needed for a goat but i am sure some are the same.
