9" wheel bearings with oring part #?
Looking for the part number or if anyone knows where I can get wheel bearings for my moser 9" with 31 spline axles. I had a part number and went to autozone, advanced, and napa all had the bearing but none had the bearings with the oring. My axle seals leak like something terrible and I refuse to put my new weld rts' on the car until i have new axle seals and the bearings with the orings. Please help
Did you see this page O' bearings?
http://www.moserengineering.com/othe.../bearings.html
My S60 uses Timken Set20 tapered rollers they have good seals, can you upgrade to them? AFAIK Ford used them on the 9" also.
LS1Tech Sponsor
Bearing: 88128-R
Inside Seal: 15142
Prior to installing the (inner housing seal) axle seals, RTV' all around the inside where they are going to get tapped in. Once the seals are tapped in, use your finger to apply RTV around the edge of the seal. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Sponsor
__________________
