4l80 swap guys; what crossmember and torque arm setup are you using?
Old 02-27-2015, 06:20 PM
jt76's Avatar
Default 4l80 swap guys; what crossmember and torque arm setup are you using?
Need to get a crossmember and tq arm. Ideally I would have the trans X member and tq arm mount integral. I wanted to do spherical bushings on the tq arm. I have a 9" rear end. What setups are u guys running? Any advice?
Old 02-27-2015, 09:18 PM
JRENIGAR's Avatar
Im using the BMR 4l80e mount that relocates the torque arm to the bracket instead of the trans tailshaft housing. The torque arm is just their basic adj tubular unit with a poly mount. Car hasn't been driven with the new setup yet so I cant elaborate on the feel of it all.
Old 03-01-2015, 02:10 PM
Firebirdmuscle's Avatar
I have the MWC crossmember but I have the short MWC ta so my ta hooks up the the ds loop that they supply.
Old 03-02-2015, 10:39 PM
transam69230's Avatar
Same here.
Quick Reply: 4l80 swap guys; what crossmember and torque arm setup are you using?
