My car is really screwed up, I don't know what is wrong!
I have a 98 TransAm. I haven't tried to start it since I got home on Sunday afternoon. I went out this morning to go to work and the battery was dead. I jumped it off and it started up fine. Everything was okay until I put it into drive and the car stalled. I put it back in park and started it up again and it was idling real low and wanted to stall out. I reved it up to 2k rmps and held it for about 10 seconds to see if it would return to normal. No luck it idled real low and when I put it in drive it stalled out again. I restarted the car and same thing this time it was idling so low that it would stall out within 5-10 seconds. I tried starting again a few times and same results every time. It was too dark for me to look over anything at 3am this morning, so I just went back out and the battery was dead again. Any ideas what it is?? I can hear what I think is the fuel pump trying to prime but its on and off. I think its due to lack of power.
AsianIce25 is correct. My battery was dead after sitting for an extended period of time. I had to start it up and give it some gas to keep the rpms up, after 2-3 minutes it ran fine. The pcm just needs time to relearn. Nothing serious, just makes the heart stop beating for a bit!
This happened to me a week or two ago, i have an m6 and so I thought this to be rather odd. I had to start it a few times, but after revvin it up a few times and letting it idle back down....then a 30 second break after it died the last time....turned it back on and it was fine. Just let your pcm relearn the curves and you should be fine.
Plus I think the PCM will not function correctly if your system voltage is below ~8volts.
If the battery keeps dying, then the alternator is toast which means you're always on battery power...or lack thereof.
