New LS1 Owners - Newbie Tech - PO443 code? (EVAP) What can cause it?
Bowtieman4life
06-07-2004, 12:43 AM
It states: Evaporative Emission (EVAP) Purge Sol Control.
Any help will be greatly appreciated.
Thanks
Tom@SpeedInc
06-07-2004, 01:07 AM
Loose gas cap but i'd say the solenoid on the charcoal canister. Without looking at the car can't give an accurate diagnosis, but thats the general consensus of evap codes.
Bowtieman4life
06-07-2004, 01:32 AM
Where is the charcoal canister at? Thanks !
SmokingWS6
06-07-2004, 02:01 AM
If it had to do with a bad gas cap or canaster I think you'd get an evap leak code. Sounds like the solonoid could be shot. On LS1's its on the drivers side of the motor near the throttle body. Not sure how to check it, Usually I just rip emissions compnents off :jest:
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
