How much Torque am I going to loose? - Cam switch
Old 06-07-2004, 10:03 AM
Crowley's Avatar
Default How much Torque am I going to loose? - Cam switch
Going from the origional G5 cam (224/230 .571/.581 112) to a 232/236 .59x/.60x on a 114+4)
(I am doing heads 5.3L heads as well) I am hoping for at least 400rwtq, but after seeing some post am I going to be S.O.L.?
Current numbers with stock heads in my sig ..
thanks,
Crowley
Old 06-07-2004, 10:10 AM
gomer's Avatar
I just made 423rwhp and 398rwtq thru 4.10's by changing from my FM13 to a old MTI B1 (221/221 .558/.558 114lsa) cam. The key is having all the bolt ons, damn good heads, and a good tune.
Old 06-07-2004, 10:13 AM
Crowley's Avatar
I'm thinking that going with a bigger cam (listed above) that I am going to loose some tq though ... hopefully not...
Crowley
Old 06-07-2004, 10:17 AM
gomer's Avatar
My larger cam that I took out made more torque.. that's what I was getting at. 25rwtq more. I think the larger cam will make more. Go find all the 6 speed dyno graphs you can of cars with heads and cam packages. Everyone of them will make peak torque between 4800 and 5000rpms. A big cam starts coming on good in that range, so you'll have a higher peak torque number with a big cam... now at 3,000rpms it'll be a different story
Old 06-07-2004, 01:28 PM
LS1TECH Sponsor
foff667's Avatar
yah you might loose some downlow tq, MIGHT, but you'll gain all and then some after 4000-5000rpms id assume.
Old 06-08-2004, 09:39 AM
Crowley's Avatar
That was 400 rwtq ..
thanks,
Crowley
