Help with this cam
Help with this cam
What else do i need to do to my enigne....ie push rods..etc to this 03 Z06 Cam, here's the specs on the cam.
550"intake and exhasut lift-218 degree exhaust duration, and 204 degree intake duration at .050, and 117.5 degree lobe centers.
Any help would be greatly needed and i know you guys know all about it.
Thanks,
Kenny <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Thanks,
Re: Help with this cam
I believe the base circle on the 03 Z06 is smaller than the stock LS1. You will need to measure it to find the difference. I think that the 03 LS6 heads have longer valves that make up the difference so you will have to use a different length of pushrod. Do a search. You should find the info you need.
