Sponsor Sales & Specials - New CompCams adjustment pushrods
View Full Version : New CompCams adjustment pushrods
Nasty N8
06-11-2004, 02:44 PM
Frustrated by having to deal with the non-adjustable valve train on your LS1 engine? :cry: COMP CamsŪ has the perfect solution with their new LS1 Hi-Tech pushrods, which are now offered in seven different lengths to allow total engine builder tune-ability. Need that in between size well here you go. :drive:
For high performance applications, the ability to adjust the valve train becomes important when engine modifications such as the machining of cylinder heads, altering valve length or the camshaft base circle dimensions are changed. The stock LS1 valve train has a fixed rocker arm system that cannot be adjusted to take advantage of these common performance modifications. With seven different 5/16-inch diameter pushrods, ranging in length from 7.325-inches through 7.475-inches in 0.025-inch increments, COMP CamsŪ has the right length pushrod for your LS1 valve train.
COMP Cams LS1 Hi-Tech Pushrods
Part Number: #7794 - 7.325", #7950 - 7.350", #7795 - 7.375", #7955 - 7.400", #7796 - 7.425", #7956 - 7.450", #7797 - 7.475"
Ready for Shipment
Enjoy Nate :)
AL SS590 M6
06-11-2004, 07:29 PM
Damn a day late and a dollar short. These are just what I needed. But alas I had to spend $400+ on adjustable rockers instead.
