Guage hookup
Guage hookup
I need the best place to pick up a switched 12 and the dimmer for my water temp and shiftlight. I originaly had the shiftlight tapped into the pick wire under the steering column with a crimp style line tap but that was a piece of crap and shedded the wire in half today. I want to be able to properly do it and have it fused. Would that only leave me to tap/solder to the back of the fuse box? I don't think I can get an iron back there. It is a little tight with the door there. Could I tap the wires behind the TCS switch? It seems that would be the most roomy place for me to work. Thanks all.
Copy & Paste Moderator
If you are thinking about the TCS switch, you can use the wires behind the radio. There should be more room there to work.
Here is a wiring diagram for behind the radio:
http://www.houston-f-body.org/tech/monsoon/HeadUnit.htm
