Which cam to go with other than Hotcam
Old 06-13-2004, 07:48 PM
z28chad27's Avatar
Default Which cam to go with other than Hotcam
I would like to get a cam for my 2002 z28 m6. The cam needs to be reliable and good for a daily driver. I want the cam to have an agressive idle, but still be reliable. I do like the way hotcam idles, however i do not like many of the things i have read about it. Everyone always says that there are a lot of cams out there which would be better to go with than the hotcam, but what are they? I would greatly appreciate any of your suggestions.
Thanks in advance
Old 06-13-2004, 08:42 PM
pdd
pdd's Avatar
TR224 112lsa
Old 06-13-2004, 10:01 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Chad you might also consider our new 225 camshaft... Here's dyno results from a 225 cam M6 car with stock heads
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 06-14-2004, 03:02 AM
z28chad27's Avatar
will the 225 camshaft have an agressive idle? Sorry im a noob to the internal engine stuff.
Old 06-14-2004, 07:53 AM
DaddySS's Avatar
The idle is as much dteremined by LSA as lift and duration - any of the smaller cams with a 112 will give you a nice chop and be driveable.
