Comp 927 vs Comp 999 Spring
I've got 927's right now. The max lift is suppose to be like .700" what is the max they really are, and how do they compare to the 999 Spring.
Suspended Sponsor Account
927's- Installed height 1.95 with seat pressure of 197 coil bind is 1.175 recommended max lift is .650 will handle .725 with .050 clearance (spring rate is 488)
999's- Installed height 1.900 with seat pressure of 196 coil bind is 1.090 recommended max lift is .700 will handle .760 with .050 clearance (spring rate is 633)
