I cannot get air to come out of my vents
Old 06-18-2004, 04:15 PM
v8juice's Avatar
Default I cannot get air to come out of my vents
My heat and air work fine but it is blowing the air out at my feet only.I get no airflow from my dash vents.Can someone please give me an idea for a fix before I go and tear my dash apart.Thanks
Old 06-18-2004, 04:20 PM
slow's Avatar
check you vac lines.
do any work under the hood? its very common when doing heads to knock off a vac line, that controls the vents.
Ryan
Old 06-18-2004, 04:41 PM
v8juice's Avatar
Ryan
As a matter of fact I just installed a new intake..Ill take a look,thanks
Old 06-18-2004, 04:50 PM
v8juice's Avatar
Ryan,or anybody for that matter...You wouldnt happen to know where the vac line for the vent controls is connected would ya?Back of intake or somewhere else?Thanks
Old 06-20-2004, 05:18 PM
Black02SS's Avatar
I had the same problem when I installed my LSX intake. The lines are on the back of the intake. I can't recall, but I believe there are two of them. Fixed my problem.
Old 06-20-2004, 08:55 PM
apexman's Avatar
Yep, probably most definantly the vac. lines behind the intake. Same thing happend to me. One was not secure enough.
Good luck.
