Comp OEM replacement lifters - orientation?
So, which way do they go?
The instructions said look for an arrow or the word "up", but I don't see one.
And there is a difference in the 2 sides. THere is a small hole in one side.
Which way should I orient that hole? Does it matter?
TT-TECH Veteran
I don't think it matters I think they might be refering to the plunger side and th roller side? I would say put the hole facing towards the exhaust side IMO. I would think that it wouldn't matter because the oil just holds in the groved portion to provide a thin film of oil for them to ride on ETC... Good Luck! You could also see which way the stockers hole is facing ETC...
I can shift faster than you.
Originally Posted by DietCoke
It doesnt matter which way the oil hole faces. Roller down facing cam, plunger up to hold the pushrod.
Jason
