fired up for first time and i have a rough idle
Old 06-27-2004, 06:31 PM
cgworth's Avatar
Default fired up for first time and i have a rough idle
the engine and pcm were both used annd did not come from the same car. i put a GM hot cam in also. The car will not stay running unless i put a small piece of paper under the throttle to shim it open. i have read that the engine has to run for awhile in order to learn the cam. Is this the case here??
I also have LS1 edit but have never used it before. Is there any one who is an expert or very well expierianced with LS1 edit thaty wouldnt mind me giveing them a call to answer a few questions.
