How do you change rear axle bearings?
they are all pressed on exept the front pinion bearing. there is many ways you can do this, the best way is to use a bearing spreader and bench press. the other ways you can do it is with an air hammer (very anoying) or a torch. honestly, if you dont have a bearing that is bad, i would not reqamend changing them just for the hell of it. there cheap but a pain in the ***.
