Thinking about swapping 4L60e to Th400, what additional parts will I need?
Originally Posted by Naked AV
Yeah, you'll need one of these too.
The Gearvendors unit definitely will not clear the stock torque arm mount setup, and maybe not even the aftermarket torque arms that bolt up to a chassis mount in the tranny tunnel.
It's not impossible to install, but it's not plug and play.
Originally Posted by Dean98TA
I checked into what it would take to get one of those to work on my car, and it requires I change the stock torque arm setup to something else, like bolting up to a crossmember closer to the rear end.
https://ls1tech.com/forums/showthrea...&highlight=***
this is the absolute cheapest way you can do it, if your low on cash like me.
