How do I drop the gas tank?
Old 07-01-2004, 04:23 AM
Z28Venom's Avatar
Default How do I drop the gas tank?
I'm going to be installing a Walbro 340. Are there any instructions on how to go about dropping the gas tank.
I have true duals dumped at the axle so dropping the tank should be alot easier.
Thanks for any help or links.
Old 07-02-2004, 01:09 PM
onehardmaro's Avatar
Remove the panhard rods maybe the tq arm(mine was already out) get a jack on each side of the car(body) wedge the wheels remove shocks from rear lift the body remove heat shields and tank straps. Dont forget the screws for the filler hose on the outside of the car. Once you get under the car its easy to figure out, about 15min.
Old 07-02-2004, 01:29 PM
hourang's Avatar
make sure your low on gas.
Old 07-02-2004, 02:48 PM
Z28Venom's Avatar
Thanks for the help guys. Since the car's interior is going to be stripped for sound dampening and stereo and nitrous install. I'm just going to cut that little trap door.
Thanks
Old 07-02-2004, 03:56 PM
hourang's Avatar
Thanks
good deal
