4 channel rear into a car with 3 channel ABS?
I know the difference between the abs provisions for a TCS car versus a non-TCS car. The question is... Will a TCS rear end work in a non-TCS car?
TIA
TIA
TIA
TIA
the 4 ch axle rings have 47 teeth, the 3 ch posi ring has 110. the cars pcm wants the pulse it was designed for. how to adapt the axle pulse to mimick the posi pulse fooling the pcm is the hurdle. Plus, if it's not perfect your sensor could tell the computer your skidding and activate ABS randomly
Somebody should invent this adapter to work both ways as the need is here, but until then it's best to buy a rear with your style already built in.
I just asked this about a week ago. I did a search, but didn't come up with anything off hand. I do try that first aswell.
SUX2BU and Chief455 were very helpfull with this. I can PM you the conversation from Chief455 where he was very detailed with the responses and let me pick his brain with different what if questions.
